Mazda Trucks \  clutch master cylinder with 20's?
Mazda Trucks Make Specific
views 225
replies 5
following 5
lowwphatt   +1y
i am looking 4 information on what 2 do about the master cylinder rubbing the tire when truck is laid out w/3" bodydrop? i moved it up 1" and it scrubs the tire any help would be appreciated
slammedstroller   +1y
it really depends on how wide your wheel/ tire is.... I'm running 20x7.5 wheel with a 30 series tire and I just rotated the thing about 20 degree's towards the motor. it clears
tre5   +1y
I am running a master cylinder with a remote res. I am running it inside the cab.
LaynRockers   +1y
Or you can do what I did and ditch the 5 speed and put a auto in it. I know a auto is even slower then the stick but I did do a motor swap as well and with what you are having a problem with is one of the few reasons I went with a auto trans.
riddinlow99   +1y
you could go with a wilwood pedal assembly that has the masters built into the pedal assembly that face forward in the cab then you can have a nice clean firewall
