question about fuel cell and pump for body drop
sscrock64@aol.com's avatar
baggednbad91's avatar
baggednbad91
i am currently body dropping my 91 full size chevy. i need some input on my best course of action with regard to my options for a fuel cell and or fuel pump. i have seen people in the past section the stock tank but i would preffer an aluminum cell. if i go with the aftermarket cell can i use my stock in tank fuel pump or do i need an external and what size and psi pump would i need?
kaoss's avatar
kaoss
there are a couple of individuals on here that can build you a custom tank and use your stock sending unit and pump. May be search "fuel cell" I'm sure someone will chime in.
As far as the psi, really any inline fuel pump from Summit would work, unless you have a silly amount of horse power. Call up the local parts store and see if they can tell you the psi on the stock unit.
With my mazda I found that it was just easier to use the stock tank, relocted behind the frame rails, but I do know about your space situation.
