using the stock fuel tank in a 2001 s10?
draggindime01
The question is what do I do about the fuel lines? Their to short to reach inside the bed and rubber fuel lines I dont think will hold the pressure at the fuel pump. Does anyone know a cheap reliable fix to my fuel line problem? I dont really wanna buy a fuel cell at this point in time.
Young BBC's avatar
Young BBC
rubber fuel line would work fine. an s10 only has about 45psi of fuel pressure max. we did that same thing on my buddys toyota EFI and no problems. just get some barb fittings (ACE HARDWARE) that fit inside of the stock fuel line and into the new line and use some hose clamps, youll be fine.
Draggin2hell's avatar
Draggin2hell
yea rubber line works fine thats what i have on mine
draggindime01
So rubber line will hold the pressure...right? If so daniel...how did you go about putting it together?
TwistedMinis's avatar
TwistedMinis
Just get EFI line. It has a blue liner on the inside and will hold up to the PSI your truck puts out. Standard fuel line will pop though.
draggindime01
Can you get that kinda line from advance or napa?
