Ask A Pro \  parallel 4 link question
Ask A Pro Q & A
views 287
replies 4
payrion   +1y
if on a parallel 4 link all 4 bars are of equal length, but the front mount holes are about 1 1/2 inches closer together then the axle bracket holes, wouldnt that make the upper bar alittle longer or do you drill the upper hole further back then the bottem hole? DID I MAKE SENSE???
mindlissmetalfab   +1y
Upper bar would be a little longer. Ideally you will probably want it angled down a couple degrees towards the front of the vehicle in relation to the lower.
BioMax   +1y
The difference in the bar lengths will be so minimal that it's probably not worth worrying about. Hopefully you have built adjusters into the bars and you can fine-tune everything once it's all together.
payrion   +1y
i have adjustable bars. just asking everything i think of as i go with this build. thanks alot
Master Fabber   +1y
I believe that is also how an instant center point is found, because the imaginary lines the 2 bars make will eventually intersect. Exact parallel bars will not.... Max will know this for sure though. JR
