york compressor on 97-03 f150
lowrange83
has anybody done this? thinks 4 any info
lowrange83
it's a 4.6L
lowrange83
bump
lowrange83
bump
lowrange83
didn't think it could be done just thoght i would see
choppedn22d's avatar
choppedn22d
Anything is possible! I know a guy that put a YORK 210 ON AN 90 fwd Buick lesabre. Or you can use your sanden pump, I think thats whats on a ford. I know thats not helpful but you my friend can be the first.
homebuilt
i did it on mine. check the profile for pics. i mounted it backwards. had to remove the fan shroud and build my own bracket. i think bigrigz put one on his supercrew. good luck cause it was a pain.
sic68
Kevin mounted his on the frame rails. Good luck its not easy and probably not fun.
bukfidy's avatar
bukfidy
It can be done...you can bolt it to the drivers side front of the motor, thats where they bolt on some supercharger kits
