can i make a 70 blazer 4x4 frame into a 2wd
randy20
can i do this? i am looking at getting a 70 blazer 4x4 but i want to make it a 2wd. do i need to find a 2wd frame or can i use the 4x4 one and bolt 2wd suspension to it?
AiredOut's avatar
AiredOut
Im just about positive you can just bolt a 2wd suspension into the 4wd frame. Its been a while since ive looked at one, but i believe most of the mounting holes are in the frame already, you just need to drill 2 holes. Find a 2wd crossmemeber and take some measurements to be sure!
SHOWTIME
yes you can convert it to a 2wd.The front crossmember on the 67-87 chev/gmc trucks are a bolt on.You could order the Potterbuilt front crossmember for that truck and be good to go with a little work.
standardbyker88's avatar
standardbyker88
i second the pb member. they look badass clean. and i seem to remember 73 up brakes swap on for easy discs.
moedaman
i have a sandblasted 71 shortbed frame for sale cheap in Gallatin,TN...615-473-7840
inissant92's avatar
inissant92
I know you can do it. I have a 76 blazer sitting in my driveway right now. SD also makes a drop member for them.check out some of the chevy forums.
http://67-72chevytrucks.com/vboard/index.php
http://coloradok5.com/
http://www.73-87chevytrucks.com/
