Chevy/GMC Trucks \  s10 rear end widths
s10 rear end widths
views 9000
replies 6
following 5
bodydropped85   +1y
which s10 rear end is 4-5 inches wider then a first gen 10 bolt? right now im either looking at narrowing my back half on the jeep or getting a wider rear end due to the high offset wheels im running.
zms2004   +1y
a newer style blazer, 4x4 disc brake rear end is a lil over 4 inches wider. you could have 4 wheel disc, plus your wider rear end.
standardbyker88   +1y
different bolt pattern though, unless you have both on your wheels
mreed   +1y
Any year 4wd S10 rear end will be 5" wider than any year 2wd S10 rear end. The width difference is 2.5" on each side and will be noticed from the outer edge of the leaf spring saddles to the brake backing plate flange...disc or drums. A ZR2 rearend is wider yet. All of which share the same bolt pattern.
bodydropped85   +1y
badass thx
bodydropped85   +1y
badass thx
blazins10   +1y
Originally posted by mreed
Any year 4wd S10 rear end will be 5" wider than any year 2wd S10 rear end. The width difference is 2.5" on each side and will be noticed from the outer edge of the leaf spring saddles to the brake backing plate flange...disc or drums. A ZR2 rearend is wider yet. All of which share the same bolt pattern.exactly - plus zr2 and bravadas usaully had a limited slip or gm called them gov-lock
