Starter Problem
gkellison46@gmail.com's avatar
Starter Problem
truck action's avatar
truck action
Edited: 1/5/2009 6:05:04 PM by truck action
Anybody have a starter problem that they solved using a remote solenoid ?
Was told this would solve the problem I've been having where the starter will not engage one out of 10 or so times!
I've replace the starter a number of times,only to have it happen again!
Dankcustoms
have you tryed replaceing you battery?
truck action
Edited: 1/5/2009 8:49:07 PM by truck action
Battery is a Yellow Top( 800+ AMPS), have a digital volt reading above the battery,shows 12.3 to 12.8 volts @ most times. Alternator is a 140 amp unit! The charging system is sound!Also the battery feed to the starter is a 0 gauge wire, along with a gound of the same from the battery to the frame & engine block!Too much draw between the ignition switch & the starter. I will take a reading on the stock trigger wire before & after.
toffeechips's avatar
toffeechips
I have replaced 3 Starters so far. and 3 starter relays. I actually hooked up a button under the hood for when it fails i can still drive if i need to. Today the problem started again. Let me know some ideas too please.
toffeechips
also to add to it, when this starting problem occurs my chceck engine light remains on LOL
truck action
Edited: 1/7/2009 8:21:02 PM by truck action
After 10 starts & no problem I'm hoping it's fixed. Need to have a week of driving to see!I can't figure how to post photo's with the site changes.E-mail me for photo's  & part number & wiring diagarm.                                                       Gary/Truck Action
truck action
Edited: 1/11/2009 11:49:23 AM by truck action
TwistedMinis's avatar
TwistedMinis
    Here you go Gary.
truck action
Thanks Seth,how the hell do you post photo's on here now??
