So I need some help with a motor swap.
cfore@bryanisd.org's avatar
stlowburban's avatar
stlowburban
So I need any info you guys have on swappin a 5.0 into a B seriesmazda.  I searched the mazda forum on here as well as Mazdatruckin.combut couldn't find specifics.  Looking especially for motor mounts.  Iknow Ultimate customs in canada used to have a kit as well but theirwebsite doesn't come up.  I also looked on Advanced Adapters andTransdapt's websites.  Also I searched Minitruckin's tech archives butthe article  on this swap doesn't seem to be complete.  Anybody knowwhat issue  that was in, I probably have it at the house. Any info fromfolks that have done it would be great.  Thanks ahead of time.
stlowburban
None of you Mazda guys got any info?  Please share.   Whats the easiest way to bolt this thing in.
scotto79
The motor mounts are easy to do, you just need the stock engine mounts.  Then just weld a small arm to the frame with a sleeve on the end.  I did that with a few braces and it was easier than trying the universal 5.0 kit from Summit, total waste of money.  I may have a pic or two in my profile.
scotto79
http://www.streetsource.com/issues2/viewPhoto.aspx?Type=Magazine+Show+Coverage&Photo=/uploads/Ownerprofiles/notlowyet/113200864359PM1331.jpg&Thumbnail=%2fuploads%2fOwnerprofiles%2fnotlowyet%2f113200864359PM1331_tn.jpg   You can see a 1"x2" arm pointing down a little even with the front of the upper arm.  Hope that helps a bit.
Deranged731's avatar
Deranged731
What year Mazda??  If it is 1993 or 1994 or newer it should be the same as a Ford Ranger 5.0 sawp.
stlowburban
No it's an 86 I think.  Thanks Scott that does help.  I've put engines in stuff that I had to build the mounts from scratch so I know I could handle it but I think he kinda wants to do it himself if he can and this was always said to be an really easy swap.  Ultimate even called it a bolt in in the old article in Minitruckin' .  Thanks for the help though.
