Chevy/GMC Trucks \  73-87 and 88-98 1 ton spindle difference
views 287
replies 3
bodydropped72   +1y
tryin to find out if there is any noticeable differences between 73-87 spindles and 88-98 1 ton spindles. im wanting to lift my 82 1ton flatbed and cant find spindles for 73-87 so i thought i would see if 88-98 spindles are similar if not the same besides the brakes so i can just bolt them up to my stock control arms. if not them im gonna hae to build some spindles and would rather not do it if i dont have to
standardbyker88   +1y
about about using a spacer at the top balljoint, and then lower the lower arms with a drop brace. like on IFS 4wd lift kits. couldnt be too hard to make.
stlowburban   +1y
Why not just build control arms with the right balljoints for the later model spindles? Would be easier than building spindles. Or ream the spindles to the right taper.
standardbyker88   +1y
yeah. arms and spacers or drop parts and spacers. hell, a lift coil might get you what you want depending how much lift you want.
