Loose Shifter?
unclesamslammed95@cox-internet.com's avatar
Loose Shifter?
FukinTukin's avatar
FukinTukin
I have an idea as to what this might be but i was going to see what some of yall thought. The truck is a 87' Mazda B2000 with a manual tranny when I put it in gear the shifter still has all kinds of play in it. I can bounce it back in fourth and side to side wile in any gear. i had a problem like this before on a s-10 and I seem to remember it being a bushing or something but it has been awile. Let me know what you think.
slmmdd97's avatar
slmmdd97
sounds like it is the throw out bearing, hope this helps
FukinTukin's avatar
FukinTukin
Would the throw out bearing make it make a whining noise at around 30 to 35 mph? Also it still shifts fine but it's just loose.
slmmdd97's avatar
slmmdd97
yes it would, I have the same problem right now going on with my d50.  I just dont have the time to fix it right now.  My d50 whines through the 1-3 gears then 5 th gear. thats right now its sitting and not being driven i dont want to break down.
FukinTukin's avatar
FukinTukin
What year d50 you got? I have one that I'm building right now for my show truck mine is a 88 is extended cab.
crux131's avatar
crux131
The whining noise and the slack shifter may be two unrelated problems.   There is a plastic/nylon bushing that snaps onto the bottom of the shifter where it slides into the top of the trans. These wear out over time. I had to replace one on my truck when I first bought it. This is what allows the shifter to have so much movement while in any gear( unless you have really screwed the transmission, but I do not think you could get into a gear if that was the case ).   The part is about 7-15 dollars and is available at the dealership. It simply snaps over the ball on the bottom of the shifter. You can get the shifter out by taking off the shift console, then undoing the bolt holding the shifter to the trans...pull it out and inspect the little white nylon piece( if it isn't there then it needs replaced..haha ).   This is all off of memory...and it has been a long time since I replaced this, so some steps may not be completely accurate. You'll figure it out pretty quickly when you get into it however.
standardbyker88's avatar
standardbyker88
yeah, that sounds like the bushing to me as well. i know that with yotas, there are a few that are a little different or something that people say feels great in their 4wds. maybe something similar is available for a mazda.
pmiller's avatar
pmiller
--------------------------------------------- Originally posted by crux131 The whining noise and the slack shifter may be two unrelated problems.   There is a plastic/nylon bushing that snaps onto the bottom of the shifter where it slides into the top of the trans. These wear out over time. I had to replace one on my truck when I first bought it. This is what allows the shifter to have so much movement while in any gear( unless you have really screwed the transmission, but I do not think you could get into a gear if that was the case ).   The part is about 7-15 dollars and is available at the dealership. It simply snaps over the ball on the bottom of the shifter. You can get the shifter out by taking off the shift console, then undoing the bolt holding the shifter to the trans...pull it out and inspect the little white nylon piece( if it isn't there then it needs replaced..haha ).   This is all off of memory...and it has been a long time since I replaced this, so some steps may not be completely accurate. You'll figure it out pretty quickly when you get into it however. --------------------------------------------- This guy's on the money.  Two diff problems.  He covered the loose shifter.  The whining noise could be the throwout bearing, common problem.  It could also be lack of oil in tranny.  Pull the fill plug on the side of the tranny.  You should be able to at least feel the oil at the bottom of the whole.  If it's not at the bottom of the fill plug or doesn't come out when the fill plug is removed, you'll need to top it off.
FukinTukin's avatar
FukinTukin
Sweeeet!!! I'm going to get get on that shit tomorrow! I got to get it back together so i can get going on the body drop and air...Thanks for all the input!
Waldog25's avatar
Waldog25
Mine is whining in 4th and 5th... I will check the fluid as well... but the info calls for 2 quarts, and that is what I put in it until it was flowing back out.
