laying a s10 on 22s
draggn97civic@hotmail.com's avatar
laying a s10 on 22s
outkastdawg's avatar
outkastdawg
ive got a 98 s10 blazer that lays on 20s now and im wanting to go to 22s with a 30 series tire everything is already cut out up front firewall is tubbed besides the wiring coming out of the driver side of the firewall what else am i gonna have to do to lay on a 22x9.5 and like i said with a 30 series tire
jaredmxg's avatar
jaredmxg
do you have controll arms and spindles? if so all you should have to do is make sure your upper bag cup is cut down to 2" instead of the usual 3. and notch for the steering if not already done.
disfiguredS10's avatar
disfiguredS10
Impossible.....dont even try it.
jk, what susp. setup do you have now? its hard to tell if you're about maxxed out already without knowing the part u r running.
bmoxley
iam almost done with mine i have upper and lowers 2in drop spin. the cut  upper brk. and i bought a set of no cuts from silverstar 7in. brake booster moved over 2in it was my 1st on doin so 2 me it was alot of work but well worth it
outkastdawg
Edited: 1/18/2009 7:52:42 AM by draggn97civic
yeah im running spindles and tubular upper and lower arms and the guy who done the bag setup said that he cut the cups down i believe and inch and a half they are suicide doors cups and i havent looked to see if it has been notched for steering i know the 30 series 22 is only a little of an inch taller than the 35s im running on the 20s.and by steering are you talking about the tie rods i almost forgot i plan on body dropping it in the future besides the 7in booster is there anything else ill need to do and what can i do about heat and is there anyway to move the computer to the inside
AVTekk's avatar
AVTekk
30 or 35 series doesnt mean anything without knowing the width of the tire bro.   the ECM can def be moved inside, just use a firewall grommet to run all the wiring back out. and ya the frame needs to be notched for the tie rods unless you pick up a no-notch kit.
outkastdawg
right now im running 225-35-20s and on the 22s ill be running a 235-30 and if i move the ecm inside do i have to run all all the wiring under the hood inside or just the wires running to the ecm and can it be done without pulling the dash cause this is also my daily
BJ_waylayed's avatar
BJ_waylayed
Edited: 1/18/2009 7:53:36 PM by BJ_waylayed
Someone may have already said this and I missed it, but you will need to built a new blower box or do away with it all together  When you get ready for the booster, check us out http://waylayedinc.com/Store/index.php?main_page=index&cPath=29
outkastdawg
yeah i know i gotta do a blower box now but until i do the body drop im just gonna modify a stock one
