Ask A Pro \  SFBD question
SFBD question
Ask A Pro Q & A
views 1075
replies 16
following 9
kaoss   +1y
The stock frame on my SFBD project is 4" tall. I want a 2 1/2" body drop. I was planing on using 2x3 3/16" square tubing to replace the frame rails. My problem is the body mounts are currently flush with the top of the frame, and if I make the new ones flush, that will essentially give me a 1" body drop. Is there any problem with having the body mounts lower than the top of the frame? I may be able to get 1/2" depending on the bushings that I use, but that still puts me short an inch. I am trying to avoid doing a traditional BD on it also, since I am 6'5"  240lb and this truck is a tiny regular cab. I have considered the option of running two pieces of 2x3 on it's side, one 3/16" and one 1/8" the different thickness to keep the weight down, since this is a 100hp truck. I appreciate the help! Here is a pic of the frame:
TwistedMinis   +1y
That looks like a Datsun.   I ran into this same issue when I did the 521. The owner is 6'4" and wanted a bodydrop. I went traditional with it, because doing a little of both was going to push the budget too far. But since you are doing it yourself, that is the route I would go. Drop the body mounts a 1/2" down below the top of a 2x3 rail and get your 1 1/2" drop from that, and go an inch traditional. You will really limit yourself on room for exhaust I think if you go all stock floor, and probably end up with really hot floors.
kaoss   +1y
Hot floors? The truck will have no heater so they may be a good thing I don't know what it would do to my fat mat though. I may get the body mounts as low as I can, see if will lay at least pinch then go from there.
maz duh   +1y
What Seth said is probably going to be your best bet. If you are careful with seat selection you probably won't even notice the difference. I have a Mazda in the shop now that is done in a similar manner as described. 2" from a stock floor and 1 3/4 traditional on top of that. The truck is cut into the rocker about an inch from being doored but the customer didn't want a traditional cut that deep so we went with the combo. Good luck with it, the world needs more Dutsuns!
beebani   +1y
Kaoss, have you thought about running the exhaust beside the frame on the outside of the rail?  I want to SFBD mine eventually, but haven't really decided everything yet.   Where are you getting 2-1/2" from, it's only 1-1/2" to the pinch when mine is layed out.
kaoss   +1y
I want it to lay flat rocker, and 2 1/2" should do that.I forgot to measure that distance on this truck before I took it apart, so I nabbed those measurements off my parts truck. It may have to lay pinch for a while.   I don't see a way to run the exhaust on the outside of the rail. Beebani, i PMed you about the steering shaft also.
beebani   +1y
Edited: 1/19/2009 4:47:44 PM by beebani
---------------------------------------------Originally posted by KAOSSI want it to lay flat rocker, and 2 1/2" should do that.I forgot to measure that distance on this truck before I took it apart, so I nabbed those measurements off my parts truck. It may have to lay pinch for a while. I don't see a way to run the exhaust on the outside of the rail. Beebani, i PMed you about the steering shaft also.---------------------------------------------got it, replied.
kaoss   +1y
on here. You are on ratsun also
515customs   +1y
I just picked up a 1969 Datsun 521. What are some good forms to look at for info?
TwistedMinis   +1y
--------------------------------------------- Originally posted by 515CUSTOMS I just picked up a 1969 Datsun 521. What are some good forms to look at for info? --------------------------------------------- Here's a link to the '71 I built. It's Toyota clipped though so it won't really help with bagging the front. http://www.twistedminis.com/SMF/index.php?topic=122.0
