narrrow a nissan titan
kevin.diel@yahoo.com's avatar
darkstar06's avatar
darkstar06
            how hard is it to narrow the rearend on a nissan titan. i need mine narrowed 4 inches on each side , im just wonting to see what im getting myself into.
belowclvl's avatar
belowclvl
dman what you putting under that thing?
darkstar06's avatar
darkstar06
Edited: 1/20/2009 7:42:48 PM by darkstar06
im running a 24  by 10.5 paladin stealths
thacru78's avatar
thacru78
I havent done one, or had one done myself but I would suggest taking it somewhere and letting them do it. Specialty tools are needed to narrow a rearend as well as custom axles, or resplined axles. I've been paying anywhere from $750 to $900 to get them done in my area. Cheapest i've found was in the Houston area for $850....but by the time I travel to Houston that $50 is ate up in gas......
darkstar06's avatar
darkstar06
thanks for the feed back.
dragginon22s
i had mine done 2.5" on each side and chris from kustom kars here in TN did it, you will need custom made tubes to go in the stock ones and he sent me stock axels off to moser to be resplined. moser does them for 110.00 a pair on the resplining.
AON-4PumpedCL's avatar
AON-4PumpedCL
It cost me $675 to have the Chevy rear end under my Armada narrowed...with Moser supplting the axles.  Now I'm going to have to pay another $675 to have it done again since I didn't go narrow enough the first time... so make sure you measure twice, then measure two more times!
dragginon22s
--------------------------------------------- Originally posted by AON-4PumpedCL It cost me $675 to have the Chevy rear end under my Armada narrowed...with Moser supplting the axles.  Now I'm going to have to pay another $675 to have it done again since I didn't go narrow enough the first time... so make sure you measure twice, then measure two more times! --------------------------------------------- yeah makes sure to get enough the first time. and if you have your stock axles resplined should cost you over 400 bucks i paid 350 to have my titans rear end done.
stlowburban's avatar
stlowburban
You should be able to get the housing done for a couple hundred bucks. My axles from moser were $235.00 andthey don't taper so you can get em narrowed more later if needed. I have a little under $500 in my 12 bolt with all new seals and bearings.  The housing is not hard, you just gotta have the jig to keep em straight. Find the local hot rodders and drag racers and they can steer you in the right direction.  I have a guy in San Antonio that did my housing .  I could give you his number if you can't find anybody.
darkstar06's avatar
darkstar06
thanks, im sure one of these drag racers  can get me someone arround here that can do it. i just hope that i dont end up paying out the ass for it.
