Ask A Pro \  rod end with 3/4" stud
Ask A Pro Q & A
views 253
replies 5
pmiller   +1y
   Max,
I'm about to triangulate my lower control arm on my 89 toy.  I have a rod end that I wanted to use for this.  It's a standard 4 link rod end, but the stud is only 3/4".  I'm wondering if this will be strong enough to hold.  I would think it would be since I'm only adding this piece to the original control arm.  What do you think?
pmiller   +1y
bump
mindlissmetalfab   +1y
I really dont think that would be an issue as long as its a quality part. 3/4" ends are used in high HP 4 link setups all the time so i'm sure it would handle your application considering the front arm mount would still be stock.
pmiller   +1y
Thanks Joel.  I just needed some professional reassurance before I spend some time and money into modifying those arms.
BioMax   +1y
Wow! I'm positive that I responded to this post. Weird...   I'm not positive what you are asking, but as long as the part is a high quality heim, I don't think that you should have any problem.
pmiller   +1y
Thanks Max,  I've been running into a lil' prob posting sometimes too.  But really, thanks for replying.  You guys helped.  I've got to go back and check into this issue some more.
