explorer booster (again!)
salernom78@yahoo.com's avatar
severedmikey's avatar
severedmikey
so i just put an explorer brake booster on my 97 f150 and the shaft where it hooks to the pedal is about 4 inches to short from reaching the pedal. I just wanted to see what most of you have done or would do in this situation.
groundedbigbody's avatar
groundedbigbody
cut your factory one and add to the one that you have put on to make up the few inches your missing (make it longer )
severedmikey
--------------------------------------------- Originally posted by groundedbigbody cut your factory one and add to the one that you have put on to make up the few inches your missing (make it longer ) --------------------------------------------- theoretically that seems like the easiest thing to do without seeing it, but the explorer booster the shaft isnt that long and is coming out of pressed in oily rubber bushings that would get really hot and probably melt if you welded that close to them.
groundedbigbody
ok you could thread both sides and use a screw collar to connect it
severedmikey
yeah. cool. thats what im gonna do! thanks for the help
ONE_LO_SVT's avatar
ONE_LO_SVT
mine was lengthened,  i have about a 1/2 play in the pedal before it actually brakes, but it does the job.
CamberOz's avatar
CamberOz
any pic's of the install, i am planing on doing this over the summer
severedmikey
I will take some while doing it. i still havent finished it yet cause im in the middle of other stuff to but ill put some up when i get it done.
CamberOz's avatar
CamberOz
also any thoughts to switching to a  Hydro Boost rather then using the explorer booster
ONE_LO_SVT's avatar
ONE_LO_SVT
im thinking about it, just doing my research now, if you have any info about doing a hydroboost on our f150s please let me know.
