Ask A Pro \  narrowing suspension
Ask A Pro Q & A
views 277
replies 2
following 2
standardbyker88   +1y
so, on my 78 toyota the entire front suspension (uppers, lowers, spring cup, ect) all bolts on to the frame. id like to get a 2nd crossmember/suspension and narrow it. just a bit. like 2" maximum, so when i set the new one up i can run a little more offset than what i have to now. i can find wheels, but choices are very slim. i have a 16x7 with +40 and it barely tucks front and back. so, if i was to bring all the arms in, and readjust the tie rod ends to where the alingment is still good, will there be any ill effects? i thought about just narrowing the lower control arms as well. if it helps, i also plan to get some of the new drop from 89-95 drop spindles and brakes. i love the camber, but its eatin up tires.
im still tossing around ideas, but thank you for the responce none the less.
BioMax   +1y
As long as you don't change any of the mounting points and just narrow it, there shouldn't be any issues.
standardbyker88   +1y
thats what i was thinking. i also thought about moving stuff up, similar to a z. steering and all. thanks man.
