Mazda Trucks \  What wires do I keep running a carbed small block?
Mazda Trucks Make Specific
views 235
replies 5
following 5
bick   +1y
Hey ssm world, got my stock motor out and im cleaning up the firewall and frame and whatnot and i have this huge mess of wires ha ha, Im guessing i dont need the computer so is the pass side wire harness going in the trash? but what about the wiper motor? do i just take out that wire from the harness? Any tips or help would be awsome thanks inadvance....
smithchassis   +1y
study your trucks stock wiring harness and wiring diagrams, (wiring diagrams can be found at mazdabscene.com or other places online) and fuse panel, get an aftermarket fusepanel and wire up ony what you would like to keep such as wipers, signals, horn etc...
unusualfabrication   +1y
The only wires you need on a SBC are the alt, starter, distributor, and electric choke if equiped. Also you may need a power wire for an electric fuel pump unless your running a mechanical. I would just go though the existing engine compartment and see what you can use. I just used a Painless kit on my Nissan and rewired the whole truck.
boooghar   +1y
--------------------------------------------- Originally posted by smithchassis study your trucks stock wiring harness and wiring diagrams, (wiring diagrams can be found at mazdabscene.com or other places online) and fuse panel, get an aftermarket fusepanel and wire up ony what you would like to keep such as wipers, signals, horn etc... --------------------------------------------- yea, what he said - check with painless wiring
smithchassis   +1y
hooking up the SBC is pretty simple if hes a novice he will have some difficulty tieing the wiring into the wipers ignition and turnsignals on the mazda, if you were going with an aftermarket harness ron francis has the best kits bar none in my opinion ive used both painless and ron francis.
bick   +1y
Thanks guys, I checked out a painless kit lastnight and its deffinitly the way to go....
