Mazda Trucks \  5.0 trans on a small block 350?
Mazda Trucks Make Specific
views 212
replies 2
bick   +1y
Is it possible? Has anyone done this, I think it would work good with a body dropped mazda but not sure. Its so hard to find a t5 top loader trans, any suggestions?
maz2low   +1y
Edited: 2/3/2009 11:28:53 AM by Maz2low
---------------------------------------------Originally posted by BickIs it possible? Has anyone done this, I think it would work good with a body dropped mazda but not sure. Its so hard to find a t5 top loader trans, any suggestions? ---------------------------------------------Depends on the Transmission used . Also easiest is to use the GM bellhousing , sometimes the Bearing retainer needs to be machined down or purchase a machined down one for 40-60 bucks . Most likely you will use the 4spd or 5spd manual. The lower holes can just be drilled , for the upper 2 which need to be e-longated on the transmission side or have the bellhousing holes tig welded shut and re-tapped . There are alot more steps though plus the clutch    Overall I would suggest purchasing Novaks Clutch retro-fit which is around 200 which retro-fits the GM bellhousing/Clutch to the Ford   EDIT NOTICED AFTER THAT YOU ARE USING THE T-5 Transmission
unusualfabrication   +1y
Check with advanced adapters.
