Eye dropper tool giving me problems
rj@eyekandydesigns.com's avatar
eyekandydesigns's avatar
eyekandydesigns
Probably a stupid question, but I haven't ever experienced this in the many years I have been working in photoshop, but when I use the eye dropper tool to select a color it put the selected color as my background color instead of my foreground color....just started doing it a week or so ago, somehow got it back, and now it has reverted again.  I have searched the help and have looked at as many tool presets as I think applicable...but nothing...I have even tried resetting all the tools to default settings and still nothing....
I'm sure it is something stupid...but right now am having no luck with it...hopefully someone can save me the time of calling up an Adoble representative and sitting on hold forever.
DougyFrisch's avatar
DougyFrisch
Head over to your "color palette" and make sure your Foreground color is selected, your background color is prob selected which will make your eyedropper tool select to the background instead of foreground...   also note, once you switch it back to normal, there is a shortcut for if you ever want to select to the background again just hold the ALT key while selecting your color with the eyedropper hope that works out for ya bro....
eyekandydesigns
Well wasn't even thinking about that...but yeah I actually can't even select my background or foreground now that I look at it...when I click on one or the other it just open the color picker menu...and yeah been using the alt key to do the reverse since this happened to select the foreground color...but when you get use to do something one way for years...agghh...any more suggestions or should I just give good ol Adobe a call?
Shaven
Im guessing you already tried closing PS and restarting it?
eyekandydesigns
yeap, it has been happening for a couple of weeks now...just been dealing with it..but it is kind of odd and would like it back how it was
Shaven
well hope you get it man, I kno the feeling of things messin up like dat
DougyFrisch
--------------------------------------------- Originally posted by EyeKandyDesigns Well wasn't even thinking about that...but yeah I actually can't even select my background or foreground now that I look at it...when I click on one or the other it just open the color picker menu...and yeah been using the alt key to do the reverse since this happened to select the foreground color...but when you get use to do something one way for years...agghh...any more suggestions or should I just give good ol Adobe a call? --------------------------------------------- now which color palette did you go to? the one on the left with all your tools, or the actual "color palette" on the right hand side where you have all the RGB/CMYK sliders? go to the one on the right side and make sure the foreground color has the black stroke around it, it's a very thin stroke but you can select it, and if you click it again then yes it will open up the color picker... but i'm fairly sure that's your problem, since thats the only way to color pick to the background and not the foreground other then ALT.
eyekandydesigns
That was it Doug...you the MAN....I knew it was something stupid...I have my workspace set up not to open the color palette box on the right because whenever I need a color changed I usually do it from the the one on my tool bar...again awesome to know....I knew I could count on you since you seem to know all the little ins and outs.
