Full Size Truckin General \  Oiling a EDC
Oiling a EDC
views 365
replies 10
following 7
FluffyFreak   +1y
so where do you put the oil into a EDC? can you fill em thru the top or do you gotta do it thru the side?
Slappy Mc Nasty   +1y
it sounds like you have a "york" brand edc. i use the side port to fill mine. usually what ever i remove through the trap is what i add, that way you never run dry and never overfill
lowasfuc   +1y
wheres the best place to buy and how do you know what clutch to buy i hav a taco 2.4
FluffyFreak   +1y
slappy, yeah i got a york. i need to get a oil seperator too. Onboardair.com has a kit you can use to connect your oil seperator to refill your compressor.     deflated, im goin to the junkyard to get my replacement york, there lists of cars that have yorks. as for mounts i have no idea
Slappy Mc Nasty   +1y
--------------------------------------------- Originally posted by JaydaddyzBurb slappy, yeah i got a york. i need to get a oil seperator too. Onboardair.com has a kit you can use to connect your oil seperator to refill your compressor.       ---------------------------------------------ive read alot about these edc's and i would-not re-use the oil that gets passed through the compressor and sits in the trap. if you have ever drained a trap, youd see a milky brown oil/water mixture (almost like a blown head gasket) and the last  you want is water sitting in your edc. it will eventually ruin your internals, as water in your motor would, jus f.y.i. Jay
Marcos_65   +1y
--------------------------------------------- Originally posted by Slappy Mc Nasty --------------------------------------------- Originally posted by JaydaddyzBurb slappy, yeah i got a york. i need to get a oil seperator too. Onboardair.com has a kit you can use to connect your oil seperator to refill your compressor.       ---------------------------------------------ive read alot about these edc's and i would-not re-use the oil that gets passed through the compressor and sits in the trap. if you have ever drained a trap, youd see a milky brown oil/water mixture (almost like a blown head gasket) and the last  you want is water sitting in your edc. it will eventually ruin your internals, as water in your motor would, jus f.y.i. Jay ---------------------------------------------   Werd. Why would you want to re-use oil in the first place, its only like $1.50 a bottle for non-detergent motor oil...
Slappy Mc Nasty   +1y
--------------------------------------------- Originally posted by Marcos_65 --------------------------------------------- Originally posted by Slappy Mc Nasty --------------------------------------------- Originally posted by JaydaddyzBurb slappy, yeah i got a york. i need to get a oil seperator too. Onboardair.com has a kit you can use to connect your oil seperator to refill your compressor.       ---------------------------------------------ive read alot about these edc's and i would-not re-use the oil that gets passed through the compressor and sits in the trap. if you have ever drained a trap, youd see a milky brown oil/water mixture (almost like a blown head gasket) and the last  you want is water sitting in your edc. it will eventually ruin your internals, as water in your motor would, jus f.y.i. Jay ---------------------------------------------   Werd. Why would you want to re-use oil in the first place, its only like $1.50 a bottle for non-detergent motor oil... --------------------------------------------- i could be totally wrong in Jays post, but it sounded like he was goin to re-use his oil thats passed. mentioning a kit you can connect from your seperator to refill the comp. possibly my bad, but i know people who have tapped into their oil pans, ran a line to the intake  side of the compressors and back to their oilpan. water condensation internally damaged the rings, bearings, etc.
FluffyFreak   +1y
yeah i was talking about from the seperator to the compressor, but your right about the oil beign a funky color so i probably wouldnt do that. do you guys run check valves on your EDCs?
Marcos_65   +1y
--------------------------------------------- Originally posted by JaydaddyzBurb yeah i was talking about from the seperator to the compressor, but your right about the oil beign a funky color so i probably wouldnt do that. do you guys run check valves on your EDCs?   --------------------------------------------- You have to, or else you will blow the head off the compressor... if there is too much pressure on the head it will possible blow...
FluffyFreak   +1y
i think thats what i did to mine.
