looking for a diagram for the taillights... my buddy just got a bought mazda and it had led's in it at one time long ago and now the wiring back there is all jacked up... been searching google for a long time and havnt found anything... thanks in advance for any help...
maz duh
I don't have the diagram you need but if its only messed up on the rear you could probably unplug it at the rear of the cab and replace it with one from a donor truck. Then your not stuck with previously bastardized wiring. I used to have a Hardbody daily that suffered from a similar issue, mine was butchered trailer lites from a previous owner. The harness was farked pretty bad so I just replaced the rear section and my issues were gone. good luck with the project.
bumlove_blue
Hi Taillights and markers Black is ground Red and Black Markers and l/p light Green black LH signal Green White RH signal Red White Reverse White Green Brake Lights First colour is the main colour second is the stripe, this is out of the shop manual hopefully I interpreted it properly hope it helps!
