Chevy/GMC Trucks \  Solenoid Problem?
Solenoid Problem?
views 727
replies 19
following 12
JboyDrags   +1y
whats up folks, i know some 1 will know how 2 fix this problem. i'm running a toggle switch for my 2 compressors i have on my truck. the toggle switch is ran 2 the solenoid and that solenoid gets really hot and eventually burns up. i was curious if there is n e thing else i could use so i dont have this problem n e more.
truck action   +1y
I had a door solenoid do the same thing. Was  ground problem, i ran larger wires & made sure I had them to a better grounding point! Hope this fixes your problem!
JboyDrags   +1y
kool deal, i'll check that out
JboyDrags   +1y
chamillion   +1y
WHat kind of solenoid are you using? J/C
JboyDrags   +1y
--------------------------------------------- Originally posted by chamillion WHat kind of solenoid are you using? J/C --------------------------------------------- a ford solenoid
laydsuzu   +1y
wired up wrong.....run relays, take the solenoid off.....relays work much easier and much more reliable/easy to replace....get you 2 30-40 amperage relays and wire em up and call it a day....
JboyDrags   +1y
thanks scooter i'll try that 2
chamillion   +1y
The ford solenoids are not intended for continuos use. You need to get  a heavy-duty soleniod like a Pac 80 or Stinger , like this W/ this you won't have to run 2 relays for your compresssors.
tuckinlugs06   +1y
yea i have used the ford ones and even the ford rebuildable ones that are more heavy duty and still burned them...now running a stingger and had no probs yet
