Air Ride Suspensions \  who has bagged an escalade or tahoe? i have questions
Air Ride Suspensions Q & A
views 199
replies 4
FKAHNDA   +1y
i have an 03 2wd escalade and i would like to lay it out. i am not sure what kind of brackets or link setup i need to buy or where to buy it at. i have everything for the air setup bags, valves ect... i would sure like to get some feed back from some knowledgeable peeps. thanks in advance for your input.
//Trigger\\
oldskool66   +1y
Edited: 2/21/2009 2:20:37 AM by oldskool66
well if it was me and i was trying to keep the rear seat i would use a parallel 4 link with a wats link. just my .02
FKAHNDA   +1y
i ditched the rear seat when i had the stereo built for the truck //Trigger\\
groundscr8pr   +1y
talk to ekstensive 281 442 1050 . they have a kit for the front that raises the upper arms and has new lower arm and torsion style bag mounts. i believe it will lay on a 24. the rear will need to be custom. you will likely need a fuel cell also. u could easily a parallel link and bags over the axle. should be no prob to put back seat in too. will also need to raise trans x member and tub the firewall and rear if you want to lay frame. rearend will need to be narrowed about 2" depending on wheel size.
GetLow   +1y
If I were to do it again I would definately use the Ekstensive front setup. They can make you a fuel cell also. The factory four link is pretty much worthless if you want to get low, and you'll also have to get rid of or rebuild your rear a/c box to lay out.
