64 c10 bolt pattern options
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
is there any way to run the s10 bolt pattern on a c10 or the 5x4.5 got some free 20's and the fit a 5x4.5 and another 5 lug but its s10 i think .other than adapters is there a way and with adapters would a 20x7.5 40 offset tuck
str8azztaco's avatar
str8azztaco
chances are you'll need adapters/spacers to keep them off the frame rails when turning. It should be easy to figure out the spacer width if you already have the wheels tho.
smithchassis's avatar
smithchassis
your definatly gonna need those adapters for the thickness of them not just the bolt pattern
tuckinlugs06
with adapters the wheels wold not only hit the fender but poke way out...
tuckinlugs06
what makes  you think they would hit the frame
tuckinlugs06
20's on a fullsize it like 15's on mini they are small
