Air Ride Suspensions \  upper arms question
upper arms question
Air Ride Suspensions Q & A
views 237
replies 4
tuckinlugs06   +1y
whats the pros cons to miving them out more to get less camber...or should i make the arms longer or move the mount to the other side of the plate ..thsi all is on a 93 2wd bodydroped trying to put my 20's up from its lays on the 215/35/18 but with the 225/30/20 its about 1" from laying and with the camber adjusted it may lay also i am going to notch the lowers a little ...but what i need to know is what to do about the camber..problems is the 20 when layed out hits the brake booster just barly but i have burt them up from riding low and the heat from the tire busted it ...
tuckinlugs06   +1y
how can i fix the camber with out drop spindles
unusualfabrication   +1y
You'll get a ton of positive camber when the arm flatens out though the suspension travel if you just shim it out or make it longer from the stock mount.
TwistedMinis   +1y
Drop spindles are your friend.   I have paid as little as $150 for a set of AIM spindles with shipping. You could probably find used AIM spindles cheaper, and used DJM around that price.
maz duh   +1y
X2 on the spindles. They way you are talking about doing will only solve one issue and cause several more. Watch e-bay or try a want add on here for a used set or go with AIM for a new set at a good price.
