Shaved door kit
Shaved door kit
cavanaugh
   What shaved door kit does everyone recommend for the 92ish body style? Autoloc or AVS kits?  Autoloc has those bigger door actuators vs AVS has those slim actuators.  What works better?
cavanaugh
bump.......
loudciv's avatar
loudciv
seen the avs kit for the silverados & its very nice. if they make one for the zu, i'd go w/ them over auto lock.
tacokane's avatar
tacokane
I would just buy a set of good quality solenoids and purchase a high quality alarm and maybe remote start like a viper or python kit and wire your solenoids to the alarm kit. I've done this with all of my installs and I've never had any problems, and the range is awesome. Otherwise spal makes a heavy duty door kit.
Ron_autoloc's avatar
Ron_autoloc
Floatn,     At the heart of any shaved door handle system is the solenoid. If the solenoid you install doesn't have the power and durability to reliably open your latches on the first pull you will be stuck with endless headaches and burned out solenoids. Lesser quality shaved door kits might open your latches at first, but it only takes cold weather or a little rust or foreign material to make the poundage required to open your latches go way up. This can leave you stranded with burned out or damaged solenoids. By putting military grade high torque power in the hands of the consumer, AutoLöc solenoids make you immune to the rusty or sticky latches that will burn out lower quality solenoids. The 35-pound Power Pull solenoids in the SVPRO3 kit feature compact designs and durable steel construction. This makes them the ultimate solenoids for any shaved door handle application. Most shaved door handle kits on the market are sold with receivers designed for a remote trunk release, not shaved door handles. This means you'll have to push the button twice or hold it down for more than three seconds. AutoLöc solenoids are specifically designed for prompt activation, ensuring that your doors will open without delay. CLICK HERE FOR A LIST OF KITS FOR YOUR TRUCK  10% Off for SSM members
Ron_autoloc
We know how the slim dual actuator door poppers as well.
Related Discussions in Isuzu
