Mini Truckin General \  Sectioning Bumper Cover
views 306
replies 6
following 6
bodydropped95   +1y
What are yall using to connect the pieces back together...The bumper is like a polyurethane mixture
tuckinlugs06   +1y
never done this but i know you can skuff up the back sides really ruff and use soem fiberglass and some fiber matt ...and the make some compound thats made to joint plasyics back together ,,all i can really tell ya ..mabe soem one who has done this will chime in
slammedcivicsi   +1y
Fusor works best, depending what style of plastic it is, the 142 works well. Most thermoplastics can be welded back together, and patched.
tuckinlugs06   +1y
ill post a link to a feeinds build where had to do this so you can get an idea and also check fiberglassforums.com they do this stuff all the time...about half way down   http://www.whynotfab.com/forum/viewtopic.php?t=2574&postdays=0&postorder=asc&start=120
tuckinlugs06   +1y
here this page shows when is did it the 1st time
bodydropped95   +1y
thanks for the link
xtremelx88   +1y
Edited: 3/4/2009 11:37:32 PM by oldskoolford
this is what my brother used to do his bumper. he had to lengthen the sides so he cut them spaced them and filled then sanded it downand then some bondo to smooth it out, it is the 142/143 that he used and it came out greathttp://www.lord.com/Home/ProductsServices/Adhesives/FusorAutomotiveAftermarketProducts/Products/PlasticAdhesives/tabid/3401/Default.aspx
