Ask A Pro \  s10 blazer help
s10 blazer help
Ask A Pro Q & A
views 285
replies 3
slmd86   +1y
i have an 86 s10 blazer front set up drop spindles, and drop lower control arms, with cylinders. back setup  4 link notched with cylinders, also a 6.5 inch body drop im about an inch off the ground in the front lower control arm is hitting frame, i was wondering if i could notch the frame right there where its hitting and box it back in.
thanks
andrew
SoloSpecialties   +1y
Edited: 3/5/2009 10:36:06 PM by SoloSpecialties
EDIT: nevermind i cant read..missed the part on the drop LCA's
travis98s10   +1y
Edited: 3/5/2009 10:46:44 PM by travis98s10
What kind of control arms are you running and what size tire?  Edit*  With a 6.5" bodydrop Im assuming you are running a smaller than stock tire, so I would ditch the drop lca's for stock and keep the drop spindles and you wont need to notch the frame. Just adjust the mounts for the cylinders so they almost bottom out when laid out and you should be fine.
lobdyblazr   +1y
What kind of LCAs? not the old school kind with spring cup is it?
