park bypass on in dash dvd
11 following
thebrantleys3@gmail.com's avatar
LndRanger86's avatar
LndRanger86
i am installing a in dash dvd this week . never put one in before , and was wondering how to bypass the park only feature. it only plays dvd in park. how can i bypas it to work all the time? its a clarion 6.5 double din in dash. thanks
lwrlvl's avatar
lwrlvl
The wire from the stereo that go's to the parking brake you can just run it to a on/off witch to ground.  On mine you have to sitch it to on then off then on agian same as pushing the parking brake on/off/on but you can still drive.
LndRanger86
i got ya. thanks
artsar's avatar
artsar
if you get lucky, like i did, just hooking it up to a ground will work. I have an inline switch, but it turned out it didn't make a difference.
CalvinRollin720
dual and jensen you'll need a switch.. clarion im not sure but juss hide the switch .. and like  lwrlvl said you will have to switch on-off-on then it will take about 3 seconds to come on...
SuperBad706's avatar
SuperBad706
I got a Sony and its works fine with the brake wired to ground
LndRanger86
thanks . we'll see around thursday.
ShakinPlates's avatar
ShakinPlates
Pretty sure you can just ground the brake wire on Clarion's
276mightymax's avatar
276mightymax
LowXpectations91's avatar
LowXpectations91
you can skip all that, no ground, no switch...its illegal but i knew a guy who worked at best buy and he had access to all the bypass codes to every in dash...and he jus typed it in and good to go..so if you kno sumbody who can get that...its definately worth it.... because even your ground is illegeal off the parking brake
