compact brake and clutch master cylinder?
1 following
thenephilm avatar
thenephilm
I'm in need of a compact brake and clutch master cylinder setup...doesn't need to have pedals because I'm one-off'in the entire pedal assembly..I'm going to have disc brakes all around with around 400hp...can be a manual setup but I'd be ok with power depending on the size of everything...It's going in an s10 but that really doesn't matter because neither the motor nor the rear end are chevy parts lol...any suggestions?  I found this  here http://www.ecklerstrucks.com/product.asp?pf%5Fid=120004&dept%5Fid=1066 but im not sure that it will be enough...suggestions?
