Bolt ?
ERI454@YAHOO.COM's avatar
Bolt ?
ERIC-B's avatar
ERIC-B
What grade bolt do you recommend to bolt the air bags to the bag mounts?  Is grade 5 ok or should I use grade 8? Thanks
low mazda's avatar
low mazda
you should always use grade 8 hardware. Grade 5 stuff ain't afe. It's not rated as high weight of grade 8.
BioMax's avatar
BioMax
As a general statement, to keep novice builders out of trouble, low mazda is right. But realisticaly, there is no reason to use a high grade bolt to mount a bag. Grade 5 is fine in that situation.
low mazda's avatar
low mazda
i've had grade 5 bolts break on the front f a mazda. I won't use grade 5 anything in the suspension period.
flatblack92's avatar
flatblack92
If the bag plates stay pretty aligned like a bag over axle set up then it should be fine. If the bag sees a pretty big misalignment like on the front of a mazda the bolts will see a lot more shear load and grade 8 is the best option.
BioMax's avatar
BioMax
^^^ I can agree with that. The way that I set up my front ends the bag doesn't see those crazy angles, so I've never had the issue. Also, properly tightening the bolts play a HUGE role in breakage.
