Toyota Trucks \  differences between 93 Toyota & 03 Tacoma radiator?
Toyota Trucks Make Specific
views 143
replies 2
following 2
flntroc   +1y
Anyone know if I would have any issues if I tried to swap an 03 Taco radiator into my 93 Toy? I'm in the process of doing the 01-04 front end & instead of making brackets to make my current radiator fit I would like to just swap to a newer radiator so it will bolt right up to the core support. Thanks for any help
waynehammer   +1y
WELL IF YOU HAVE THE ROOM ITS NO BIGGIE. YOU WILL NEED DIFFERENT RADIATOR HOSES THE 1993 IS    24.41 X 5.31 X 22.83   THE 2003 IS    29.53 X 5.31 X 25.98 ASSUMING THESE ARE BOTH 4 CYLINDER.
flntroc   +1y
Edited: 3/15/2009 10:47:21 PM by FlntRoc
Yeah room shouldn't be a problem. I have nothing up front anyways. I figured I would need new hoses but was just concerned there may be something I was overlooking as far as the flow or inner workings. I assume they all pretty much work the same. I think the 4 cyl & 6cyl tacoma radiators are the same from 95-04. At least that is what I have come up from very little research on replacement radiators. Would there be a downside to the bigger radiator. Maybe just a few seconds longer to warm up? Extra money on more fluid etc. Thanks again
