Air Ride Suspensions \  control arm unijoints
Air Ride Suspensions Q & A
views 135
replies 4
broke97   +1y
wondering if someone new where I could get a set of upper unijoints for an s10 other than blf thanks ahead of time for any help
mindlissmetalfab   +1y
Ballistic  fab sells joints. If you are looking for a direct swap though I doubt you'll find it. You'll likely need a custom upper arm, and either get a tapered 'bolt' machined to fit the joint and spindle, or drill and sleeve your spindle to accept a regular bolt.
broke97   +1y
I guess Ill just make a bolt on unijoint similar to blf and drill the spindle to accept a regular bolt thanks for the info joel
jeebus @ mmw   +1y
---------------------------------------------Originally posted by broke97I guess Ill just make a bolt on unijoint similar to blf and drill the spindle to accept a regular bolt thanks for the info joel
--------------------------------------------- I can sell you all the parts you need to make a bolt in unijoint if you want.    Taylor
broke97   +1y
how much would you want for the parts chopped mazda
