toyota drive shaft tunnel
tuclugs@yahoo.com's avatar
sicsan's avatar
sicsan
Edited: 3/16/2009 3:13:41 PM by sicsan
i got a 85 toyota body dropping.how high need to lift the tunnel at the back of the cab? i run a 18 wheel. i had it with a 4 inch block and middle leaf pulled.and it would rub then  im going to 4 link it now though. but dont have t
the four link yet. but if anyone knows how high and how far up i need to go from back of cab towards the trans i appreciate it?   bobby
maz duh's avatar
maz duh
I don't know the amount you would need to raise the tunnel but may I suggest a 2 piece driveshaft as an alternative? A friend of mine did this on a regular cab to avoid tunnel reconstruction and it worked out well for him. He used the driveshaft from a king cab and had the front section shortend  up and re balanced.  A simple piece of 1 1/2 x 2 1/2 tubng for the hanger bearing crossmemberwith a couple of mounts for the carrier bearing and your done.
