Isuzu \  Tubbing firewall and weber carb
Isuzu Make Specific
views 766
replies 5
mightymini   +1y
Edited: 3/17/2009 3:04:49 AM by roadgrater
Ok I have a few questions. I'm looking to tub my firewall and run 20's, five lug conversion and all that jazz.  But the thing I was wondering is  I have a 32/36 weber carb for my 2.3, do i actually still need my ECU or do i have to relocate that some where?
bjscustombillet   +1y
I know on my 93 the ECU actually controls the distributor. Basically it senses when to advance the timing instead of doing it by vacum. So i would say your going to need to keep it unless you come up with another alternative.
pmiller   +1y
you'd have to keep it or it'd run funny unless you found a vacuum advance distributor.
mightymini   +1y
thanks guys, i appreciate the help
NR RailnPup   +1y
 your distributor should be vacume now and you should be able to unplug the comp and it should run fine if not then just plug it in agian i think its just for the smog bs it doesnt control timing on the carb trucks just efi trucks
bjscustombillet   +1y
My truck is a 93, came with a carb from the factory. When i was driving it everyday i was eliminating all the emissions crap. Theare is a plug on the distributor that goeas back to the ecu. once i un hooked it, shazam no more advance. Im not saying all the distributors are like this but mine sure was. So when i started my build i decided to do this. It started life as a MSD probillet distributor for another vehicle. I kept the top and remade the whole lower end to fit in the Isuzu head. http://www.hubgarage.com/mygarage/vehicles/14156/photos/816592
