What to drag?
14 following
pmillerinc@yahoo.com's avatar
What to drag?
pmiller's avatar
pmiller
I'm makin' a dragger out of my yota and I want to know what everyone else is draggin' on.  Drag Blocks, trailer balls, something else?
Tell me what's makin' your sparks!
tattoominitrucker
the frame... get a piece of metal and plate the bottom of the frame or bodydrop it and drag the body ............
V
vcminitrucker4lyfe
I agree with plating the frame. I don't trust trailer balls seen too many bad things happen when they break and go flying and the car behind them. I put drag blocks on one of my trucks once and I just hated how much it jacks your truck up until you drag them down. Good luck with your truck man.
no1lowr's avatar
no1lowr
just build the truck as low as you want and then just accept the fact that its way cooler to drag what hits the ground on its own. and hopefully its not ur oil pan or arms. mine drags the front bumper, 1/4 plate under the doors, and the rear frame..i didnt choose these to drag, they just do, i chose to have the truck built low and at a certain stance and look...IMO building a truck to drag something is just like puttin a pecker on your best girl!!!just doesnt make any sence.
kaoss's avatar
kaoss
Destroyed to Drag...
tuckinlugs06's avatar
tuckinlugs06
yea just make it lay bitch blocks are for pussys
pmiller's avatar
pmiller
I guess I'll just run some plate on the bottom of the frame.  Yota frames are sooo thin.  Wouldn't be able to drag it for too long.
simple-pleasurez's avatar
simple-pleasurez
just get any scrap metal you can find. obviously the kitchen broom handle made of 22g steel isnt going to work but any scraps you can find just weld to the frame. leaf springs. your neighbors fence. whatever.
ShakinPlates's avatar
ShakinPlates
I drag plate. Its a good idea to check them after every session though. Dont want to decapitate anybody behind you.....
simple-pleasurez
---------------------------------------------Originally posted by ShakinPlatesI drag plate. Its a good idea to check them after every session though. Dont want to decapitate anybody behind you.....
--------------------------------------------- what kind of plates? your grandmas china or will chinet work? kidding...
