What wheels tuck with an amigo?
graffix
I got a 94 isuzu amigo, right now I got 20s on them, but I forgot how wide they are, what backspacing/offset they have on it. But on the front they dont fit by the slightest margin.  I was wondering, what type of specs I need to look for to get a rim that would work on the amigo.
tacokane's avatar
tacokane
If your running drop spindles in the front it will push your wheels out quite a bit from stock. If this is the case you might try laying on 20s without the use of drop spindles.
NR RailnPup's avatar
NR RailnPup
when i had my isuzu front clip still, my wheels were 20x91/2 w/ 35mm offset tucked front and rear no problem w/ shaim drop spindles
sponge splawn's avatar
sponge splawn
There are no drop spindles for the amigo frame. The only way to get spindles is to go with a 2wd truck  front clip. I have a 2wd front clip on my Rodeo with AIm Drop spindle and I am tucking a 22x8.5 with a+38 mm offset. My 20s I had before had in the low to mid 30s. Good luck.
graffix
Edited: 4/6/2009 9:27:14 PM by LowIzzy
Well I did find 20s with this offset:
20x8.5 +20 offset bore 78.1
Think that might be enough to tuck???
Or right now I'm running 245/35 up front..wonder if i went 245/30 up front if that would help out alot. Should be about another inch of difference in tire height,right?
Related Discussions in Isuzu
