Brown Bag Special
62 following
john@keefsrodncustom.com's avatar
Brown Bag Special
KEEF's avatar
KEEF
Bj Mills new project...here for bags, z'd frame, and bd on 22/24 Raceline billets
KEEF's avatar
KEEF
Z'd 3 1/2" so bottom of frame can be cut off for sfbd2x6" 1/4" wall cut down to 2x4 7/8" to replace rails under cab for bodydrop welding front body mounts on so rivets can be cut out in order for new rails to sit flush
post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo post photo
KEEF's avatar
KEEF
Edited: 4/18/2009 9:12:55 AM by KEEF
new rail with shifter rod bracket welded in and adjusted to work properly holes drilled and tapped so all lines are bolted to new rails  Got axle housing narrowed 3 inches per side today and notched frame then stuck the rearend on 24's under it and layed er' out
02ramon20s's avatar
02ramon20s
Looks sick, Good job.
4uh8rs's avatar
4uh8rs
damn KEEF CAN I GET SOME FRIES WITH THAT.LOOKIN GOOD HOMIE.KEEP UP THE GOOD WORK
3day's avatar
3day
Damn you Keef, you just make that look so quick and simple! Looks good bro!
Gump1986
Damn Keef looking good
avs_jason's avatar
avs_jason
So sik......
tre5's avatar
tre5
I wish I had a lift!!!!
MagicMikey's avatar
MagicMikey
---------------------------------------------Originally posted by tre5I wish I had a lift!!!!---------------------------------------------i wish i had a shop big enough for a lift!!!
