another back half question ?
dragnranger
what angle should i use to kick up the frame? i am goin to be back halfing my 92 yota. i was thinkin mabe a 30* kick up but not sure. what angles did yall use?
project94
mine's at 45, but mine are real tall
stockfloored93's avatar
stockfloored93
45 works good in my opinion.
maz duh's avatar
maz duh
I usually use 60 dergee angles when I do a subframe. You can pick up a simple drafting triangle at any office supply store that has this angle in it. Having this will make it easy to draw the subframe out 1:1 before you get to the cutting steel stage. For a backhalf blueprint you can use a piece of 1/4 inch masonite, its cheap and sturdy and is available at most any lumberyard. Drawing it out 1:1 will help you avoid any issues that may arise during the construction process and give you a reference drawing for the cut sizes of your material, deff worth the couple of extra minutes it takes. G'luck and keep us posted.
BioMax's avatar
BioMax
Agreed^^^ Save yourself time and money and draw out your suspension in full size. I tried to post a picture, but the server keeps kicking back an error.
dragnranger
cool, thanks fellas for the info. i will get pics up as soon as i can get the yota in the shop.
s10
last post by baha +1y
