Air Ride Suspensions \
Air Ride Suspensions Q & A
views 180
replies 8
following 6
danclarisjunior   +1y
Edited: 4/15/2009 7:46:04 PM by danclarisjunior
Edited: 4/13/2009 10:00:07 PM by danclarisjuniorEdited: 4/13/2009 9:59:05 PM by danclarisjunior
danclarisjunior   +1y
WHERE IS THE BUILDERS.........
scotto79   +1y
people don't like it when there are multiple posts.... and your question doesn't make sense
danclarisjunior   +1y
doesn't make sense for who dont know about....Its a technical question....
scotto79   +1y
the brake is going to camber the exact same as the wheel since its attached thats all I can get from the question, and its not overly technical
TwistedMinis   +1y
No, the way it's worded doesn't make sense. I can't tell what you are asking.
danclarisjunior   +1y
Edited: 4/15/2009 7:46:43 PM by danclarisjunior
Uncle Fester   +1y
Bom Dia!!! If I understand correctly you are asking if the weight of the vehicle will make a difference on camber?  If it is sitting on the ground then it will not change camber regardless of weight.  Good luck.Tchau
BioMax   +1y
You will get camber change from things flexing. Bushings flex, arms flex, the frame flexes. You WILL have camber change. How much is impossible to say, there are too many variables.
