Toyota Trucks \  94 yota wheel question
Toyota Trucks Make Specific
views 172
replies 3
getNlaid621   +1y
Front ---Size: 17x7.5 Offset: +30mm Weight: 23.26lbs Rear ---Size: 17x8.0 Offset: +33mm Weight: 24.14lbs Lug: 5x114.3
is this the right offset for my truck? they are 350z wheels if that helps
ahab   +1y
The offsets will probly work, but the nissan has a 66.10 mm hub bore and the toyota has a 67.10 mm bore.  Those wheels wont fit over the hub unless they are machined out.
getNlaid621   +1y
yeah i figuered that. im just not sure on the offset. thanks for the info
ahab   +1y
Only problem I see is the rear wheels.  What size tire you planning on running?
