Air Ride Suspensions \  leaning
leaning
Air Ride Suspensions Q & A
views 182
replies 3
dortonracing   +1y
when i air up my truck its leaning to the drivers side. about and inch. if i measure off the ground to the fender. what do i need to do thanks
tre5   +1y
plumb up individual controls and or switches and dump the pass side an inch after lifting...that would be the easiest thing to do.
laydout   +1y
Your gas tank weight is probly causing the lean if it is on the drivers side?..and if you have just  f/b switches..the the easiest way to fix it would be to build a fbss setup so you can conrtol the pressure of each bag..so you can adjust the lean
ProHopper   +1y
Mine does it too exactly one inch. so I cut my cups on the passengers side and guess what it's still an inch pffft!
