Air Ride Suspensions \  one piece step notch
Air Ride Suspensions Q & A
views 389
replies 5
following 5
bagged91mazda   +1y
I have a bunch of 2"x2" metal that is 1/8  inch thick.I was wondering if that would be a good c-notch.What are the sizes of a one piece c notch.Thanks
SoloSpecialties   +1y
i wouldnt advise usin 2x2,especially 1/8" wallthe smallest i would use,square tubing wise would be 2x3x3/16"
bagged91mazda   +1y
ok thanks ill just buy one thin or go see how much metal cost.I was told to cut all the corners at a 45 degree is that right.
i8nt2lo   +1y
I made my cuts for my notch at about 33 degrees or so.  The notches had about 60 degrees when all was said and done.  2x3 at 3/16" should be the minimum for your notch, just to be safe.
kaoss   +1y
Draw it out on the floor(card board if your married and building it in the garage ) with a sharpie. This has worked great for me, until the wife saw all the sharpie drawings.
maz duh   +1y
^^ It is usually a good idea to take a couple of minutes and draw it out 1:1 before you start cutting.  Sometimes the idea looks different on paper than it did in your head, drawing it out gives you the option to adjust/change things if you want.
