Chevy/GMC Trucks \  1st gen s10 wheel questions
views 424
replies 5
bagged91mazda   +1y
I am going to get an s10 this weekend.I am going to bag it.This is what I need to know.I am going to dehump the lca.and cut the frame for the tie rod.and do alittle cutting on the frame so it will clear.I want to run an 18 but Ineed my heat will a 225/35/18 fit.And what do I all need to make it lay in the front.I cant buy control arms or drop spindels yet.
bagdb2200   +1y
That tire should fit without even removing the inner fenders, and you probably won't have to notch the frame for the tie rods either.  And you should be able to get it to lay out with stock spindles, there are ppl with S-10's on 20's with stock spindles.
dwn2erths10   +1y
I layed mine on 17s with a 205/40 with drop spindles and tube lca's. I didnt remove my heat but the tire did remove the blower motor for me. If you reshape the blower box it should be fine.
bagged91mazda   +1y
I had a 1st gen blazer with lower control arms and drop spindels. with  a205/40/17 tire.I I had no problems clearing the heat box of blower motor.I dont think you should of hit the blower motor at all I would say something came yp and hit it not your tire.
dwn2erths10   +1y
No it was the tire. It hit when the front was down with the back up about 3 inches
bagged91mazda   +1y
thats weird I never had that problem but was yours bd. in the profile it is.Anybody else.
