Mazda Trucks \  350 in a Mazda with power steering?
Mazda Trucks Make Specific
views 1145
replies 11
following 10
rovert   +1y
Anyone here running a 350 in their Mazda AND have power steering?
bowtied   +1y
Bump for the post, but where would i find 350 v8 motor mounts for a 89 mazda b2200? Cause i wanna go v8 with mine! Again just adding to the post!
fxCUSTUMZ   +1y
I built my own motor mounts when I did mine.  I used tube and rod ends.  I also cut the factory mounts on the frame and moved them down and then gusseted them.  That allowed me to drop the motor down around the cross member.  But I had to notch the fire wall for the distro.
maz2low   +1y
Edited: 4/26/2009 12:14:13 PM by Maz2low
  I am running a 350(355) Small block and have Power steering. I went with an all aluminum steering pump and block mount. I converted the Mazda steering box over to AN fittings and running braided lines. The Steering pump fits in the palm of your hands. Now obviously you do not want to speed 600-700 for this pump,tank and fittings, but for $50-60 you can buy a SWEET brand steering pump off ebay and purchase the mount for 30-40 off ebay aswell.  The pump will be Cast instead and most likely the style from the Chevy cars. Just need to match the RPM up with your motor.
bagdb2200   +1y
Hey Maz2low, are you running those plug wire brackets backwards on purpose?
maz2low   +1y
---------------------------------------------Originally posted by DroptSdimeHey Maz2low, are you running those plug wire brackets backwards on purpose?---------------------------------------------
  They are run that way to match other side which had clearance/routing issues. If you saw it from a distance and location of bracket other way you would understand.
boooghar   +1y
check these cats out, we run'm on our circle track dirt cars, top notch stuff and reliable for the street http://www.krcpower.com/
rovert   +1y
Ok cool, I just didn't know how compatible the mazda steering box was with the GM or other power steering stuff. Thought I might need a different steering box or something.
rovert   +1y
Edited: 4/26/2009 4:47:52 PM by rovert
---------------------------------------------Originally posted by bowtiedBump for the post, but where would i find 350 v8 motor mounts for a 89 mazda b2200? Cause i wanna go v8 with mine! Again just adding to the post!---------------------------------------------I don't think you can find mounts for that specific application.  There used to be a kit someone made for a 302 swap, but I don't know if they are around anymore.  We are gonna do pretty much what  fxCUSTUMZ did with stock 350 mounts.
bagdb2200   +1y
---------------------------------------------Originally posted by Maz2low---------------------------------------------Originally posted by DroptSdimeHey Maz2low, are you running those plug wire brackets backwards on purpose?---------------------------------------------
  They are run that way to match other side which had clearance/routing issues. If you saw it from a distance and location of bracket other way you would understand. ---------------------------------------------That's cool man.  I was just curious if you did it that way on purpose or not.  What do you have clearance issues with on the other side?
