Best Product For Watts Link Pivot
AON-4PumpedCL avatar
AON-4PumpedCL
I'm looking for everyone's input on what they'd use for the actual pivot for a watts link.  I really like how Totally Polished used bearings, but without a machined piece for those to sit in, I don't think that'll work.  I would like something that does not make any noise (ie squeeks, rattles, etc) and will have a long life span on a heavy vehicle.  Thanks in advance.
-Aaron
jeebus @ mmw avatar
jeebus @ mmw
Im making one with a 1" spherical bearing right now, and it looks like its going to work good, but the stuff you need to maek it work right is kinda expensive.  I think it will look good when its done tho!   Taylor
get twisted avatar
get twisted
use a super pivit weld your tubing on to the side and there you go
get twisted avatar
get twisted
yes thats exactly what i was thinking
draggindakota avatar
draggindakota
Edited: 4/30/2009 3:49:40 PM by draggindakota
Wouldn't the super pivot let the watts link wobble front to back? i don't know anything about watts links, so this might not be an issue but something to think about.   What about what this dude used ---> http://www.streetsource.com/forum/topic.aspx?topic_id=105929&page=4 A camry hub and bearing. It's an off the shelf part, so if something breaks or wears out, you can just go to the parts store or junk yard.
ahab avatar
ahab
WOW.  Did I not tell you before Aaron to use a wheel bearing from a car.  Where is Jeremy at....Tell his dumbass to come look at that thread.  He said it wouldnt work.  Idiot!!
draggindakota
Yeah, I thought that was a cool idea. The link bars are also scabbed from a camry rear suspension.
humanmachinehead avatar
humanmachinehead
they mentioned the wheel bearing trick to use at school.  my buddy got one from a junk for next to nothing
unusualfabrication avatar
unusualfabrication
Only problem I can see using a hub would be the small diameter limiting the amount of lift you can get.
