Nissan Trucks \  Late 90's frontier owners.....
Nissan Trucks Make Specific
views 868
replies 10
following 6
974door   +1y
I know there aren't many out there, but I have a question. Has anyone done away with all that extra stuff on the brakes? I am not sure exactly what it is, or what they do. I think it has something to do with the abs.
gsrb20b   +1y
Are you talking about the stuff under the cab or on the rearend.
974door   +1y
Both.
frontin on 20s   +1y
Yeah i put disk brakes on mine
FATTSTRIPES   +1y
yeah, i removed the return line and got rid of the pump under the cab,of course the brake lights(in dash) on but otherwise no problems
974door   +1y
What about that thing in the back that has a spring going to the rear end?
gsrb20b   +1y
i replaced it with a t, its just a proportioning valve that works under a load. if you lower the truck with it on its like haveing a load in the bed, the brakes will lock up.more weight = more brake
HarryBalls   +1y
its garbage....ditch the stuff in the rear and tee them off like said above.
974door   +1y
Thanks fellas. That info is very helpful.
jcjcsoccerkid   +1y
so what exactly do i do to this spring. i've noticed the front brakes lock up on me. is this due to the spring?? cause if so its almost caused me a couple accidents. and i need to remove it
