my first 4x4 render
tlw32882@yahoo.com's avatar
my first 4x4 render
tlw32882's avatar
tlw32882
tell me what you think, good or bad of course
Jance Customs's avatar
Jance Customs
Edited: 5/9/2009 10:12:57 PM by Jance Customs
That looks good! Did you airbrush the driveshaft? Doing 4 x 4's are tricky because you basically have to make all the suspension unless you just happen to find a picture with all the same angles. Was it originally a uni-body? Right below the doors there is a little bit of white showing?
tlw32882's avatar
tlw32882
thanks jance, i did get lucky with the suspension pic lining up with minimal work. the drive shaft and the top of the rear axle are brushed because i raised the center section of the frame to make the proportion look right. some of the things i notice now that i should of changed are the body lines, rear passenger shock. it was a contest, not a customer rendering so i didnt have as much time to put in as much work as i would of liked.
