Chevy/GMC Trucks \  colorado wheels?
colorado wheels?
views 304
replies 4
following 5
NR RailnPup   +1y
im lookn to get some 20s for my crew cab and i was wondering what a good offset/ and width would be, so they will tuck later when i bag n b/d it?
ptman2002   +1y
what you need is a really high offset.   like a 30 or 35.  if i remember right mine are 20 x 8.5  and a 32 offset.   also have a 245 35 20 tire.  djm 3/4 drop.  only rubbage i get is when turning to the right, mine rub the sway bar.
smithchassis   +1y
please also be aware that most off the shelf wheels will not fit due to the size of the hub, most off the shelf wheels have a hub bore of 3 inches, while the colorado is 100mm in other words 4 inches, also even if you get a wheel that fits offest wise when you bag and body it you will probably have to shorten the rear end, even if its a small margin like an inch, these axles are wiiiiiide hope it helps!
ptman2002   +1y
here is where you need to go for all your info.    http://forum.355nation.net/
blurred   +1y
Yeah, that site is full of that kind of information.  I know that you can pull the body mounts in the bed a bit to get more clearance in the rear without having to shorten the axle. Can't remember what his offset was on the wheels though...
